How To Setup A Device In Amcrest View Pro 2 Using IP/Domain Setup
Amcrest View Pro 2 provides several ways of connecting your device to the Amcrest View Pro 2 mobile app. However, for the most secure method of connecting your device use the IP/Domain/DDNS method.
To setup your camera using the IP/Domain/DDNS method you will need to first port forward your device. This allows to establish a public IP address instead of using a local IP address so you can access your device remotely outside of your network. For more information on how to setup port forwarding on your device, click here.
Adding A Device Using IP/Domain
Note: To help determine the public IP address, please visit: http://ipchicken.com/ or http://canyouseeme.org to verify.
Step 1: Open the app and click Add Device. Tap IP/Domain/DDNS.
Step 2: Enter the public IP address and HTTP port number of the device, give the device a name, enter the password for the device, then tap Save.
Adding A Device Using DDNS
Step 1: Make sure the device has been port forwarded properly and set up using AmcrestDDNS. For more information setting up AmcrestDDNS, click here.
Step 2: Once the device has been set up, open the Amcrest View Pro 2 app, tap Add Device, and select IP/Domain/DDNS.
Step 3: Tap Add Mode and select DDNS.
Step 4: Enter the domain name (the format is: [Domain Name).amcrestddns.com) in the Address field, give the device a name in the Device Name field, and enter the password for the device in the Password field. Tap Save.
