How To Import and Export Multiple Devices For Amcrest View Pro Into Amcrest View Pro 2
For a better user experience, download the Amcrest View Pro 2 app. To download the latest version of the Amcrest View Pro 2 app, please visit the App or Play Store and install the app onto your mobile device.
Make sure you are currently running the latest version of the Amcrest View Pro app. The latest app will provide a banner that prompts you to download the Amcrest View Pro 2 app. Please note, the banner is only available on initial installation of the Amcrest View Pro app, closing the banner will disable the ability to generate a QR code.
If the banner is closed and the option to export becomes unavailable, you can automatically search devices on your network using Amcrest VIew Pro 2 if needed. For more information on how to search and add devices using Amcrest View Pro 2, click here.
Select the banner to view the instructional prompt and click the Export Device button.
Select all devices you wish to export to the Amcrest View Pro 2 app. and click Generate.
Note: A QR code of all your connected devices can be generated This will allow you to export and import your devices quickly into the Amcrest View Pro 2 app.
Click the Save icon to save the QR code to your mobile device. Once the QR code is saved to your mobile device, open the Amcrest View Pro 2 app and click the Add Device option and select Scan QR Code P2P.
Select the Photo icon () located at the top right corner of the scan QR code interface.
Select the QR Code you saved to your mobile device to automatically import the devices into the Amcrest View Pro 2 app.
