How To Setup A POE Camera In Amcrest View Pro 2 Using P2P
Most newer Amcrest devices should be initialized before adding it into the Amcrest View Pro 2 app. The camera can be initialized by connecting it to your network, accessing the web user interface (web UI) in a web browser and setting it up first in the web UI.
Ensure the mobile device and camera are also on the same network before adding it into the app. For more information on how to add your POE camera into the app please refer to the information provided below.
Step 1: Open the app and click Add Device. Tap Scan QR Code P2P.
Step 2: Scan the QR code on the camera or manually enter the device's serial number into the Enter camera S/N (serial number) field.
Step 3: Tap POE Camera.
Step 4: Enter a name for the device in the Device Name field. Enter the default password for the camera in the Password field. The default password will be admin. Tap Save.
Step 5: Enter the default password into the Old Password field, enter a new password in the New Password field and confirm. Tap Save.
Your device has been successfully added to the app.
0 out of 1 found this helpful
