How To Set a Video Tampering Feature Using Amcrest View Pro 2
The video tamper option in the app detects and sends a notification when someone tampers with the camera. For more information on the video tampering feature, please refer to the information provided below.
Step 1: Open the Amcrest View Pro 2 app and select your device, tap on the settings (gear wheel), access the Configuration Center, tap Motion Detection, and select Video Tampering.
Step 2: Ensure the Enable option is enabled and modify any settings if needed.
Note: An optional schedule can be set if needed by selecting Schedule.
Step 3: To set a schedule, select a day and a period, then use the time range provided to set the schedule. Tap the checkmark and tap Save to apply the schedule to your device.
