The video settings menu allows the user to access zoom, focus, flip/rotation, or image settings. For more information on the features provided in this menu please refer to the information provided below.
Open the Amcrest View Pro 2 app and select your device, tap on the settings (gear wheel), access the Configuration Center and select Video Settings.
| Tap to access the zoom and focus options. | |
| Use the + and - options to control the zoom function if applicable. | |
| Use the + and - options to control the focus function if applicable. | |
| Tap to access the flip and rotation options. | |
| Flip the image left or right. | |
| Flip the image up and down. | |
| Rotate the image left 90°. | |
| Rotate the image right 90°. | |
| Rotate the image 180°. | |
| Tap to access the image settings. | |
| Use the + and - options to adjust the brightness of the image. | |
| Use the + and - options to adjust the contrast of the image. | |
| Use the + and - options to adjust the hue of the image. | |
| Use the + and - options to adjust the saturation of the image. | |
| Tap to reset the image settings back to its original default settings. |
