Amcrest View Pro 2 Storage Status Menu
The storage status menu allows the user to view and verify the free and total capacity of a microSD card or hard drive. The option also provides the option to format a storage device. For more information on this option please refer to the information provided below.
Step 1: Open the Amcrest View Pro 2 app and select your device, tap on the settings (gear wheel), access the Configuration Center and select Storage Status.
Step 2: The free and total storage capacity of the device will be displayed. To format the storage device, tap Format.
Note: This will clear all data from the storage device.
