How To Setup Audio Detection Using Amcrest View Pro 2
The audio detection option allows the device to use audio thresholds to detect events. Please note, this is only applicable to devices that supports a microphone or audio in device. For more information on how to set audio detection, please refer to the details provided below.
Step 1: Open the Amcrest View Pro 2 app and select your device, tap on the settings (gear wheel), access the Configuration Center and select Audio Detection.
Step 2: Tap Enable. Tap Advanced Configuration to access the sensitivity and threshold levels.
Step 3: Select a threshold level and just the levels as needed. Click OK.
Step 4: Tap the back arrow and click Save to apply the settings.
