The playback menu allows the user to view, clip, and manage recordings from a device connected to the app. For more information about the playback menu please refer to the information provided below.
Step 1: Tap on Playback from the home menu.
Note: Playback can also be accessed in the live view menu if needed.
Step 2: Tap the + icon and select your device. The feed will load and the recordings will be represented in the timeline. Pinch and zoom the timeline to view multiple hours of the day if needed.
| Pause or play the recording represented in the timeline. | |
| Change the playback speed from 1x up to 8x. | |
| Playback the recording frame by frame. | |
| Enable or disable audio from the recording. | |
| View the recording in full screen. | |
| Manually take a snapshot of the event (saved in the Picture tab of the Events menu.) | |
| Manually take a video of the event (saved in the Video tab of the Events menu.) | |
| Clip a recording from the timeline. For more information on how to clip a recording, click here. | |
| View recordings in fisheye mode (applicable to fisheye devices only.) | |
| View a file list of all recordings represented in the timeline. |
File List
Select a file from the file list to view the recording. The recordings will be listed per day on an hourly basis based on how many recordings were stored in that time frame.
Use the interface to playback the recording, take a snapshot or video, as well as view the recording in fisheye mode (if applicable).
