The events menu allows the user to view and playback push notification, alarms, and other events. To access the events menu, tap the Events option in the bottom banner of the app.
The events menu will display all devices with events. Tap a device to access the events. Please note, only event notifications clicked by the user will be retained in the event list. If there are notifications that users ignore, those notifications will not be retained in the event list.
Use the provided calendar to select a day and display the events for that day. Select an event from the menu and use the provided options to view the event. This menu allows you to stop or play the event, turn audio on or off, manually take a snapshot or video recording, or view the event in fisheye mode (if dewarping is applicable). Tap Live View to view the current live view feed of the selected device.
