Charging Your Battery Camera
The battery for your battery camera will come loose in the box and will need to be installed before use. For more information on how to install the battery please click here.
The battery in some cases will not come fully charged and may need to be charged before use. To charge the camera, locate the microUSB power port on the back of your camera and use a Flathead screwdriver or your fingernail to open the cover.
Plug the included microUSB charging cable into the microUSB power port on the back of the camera. Please allow a minimum of 2 to 3 hours for charging to complete (100%). When the camera is done charging, the green LED on the front of the camera will remain solid. You can then unplug the camera from the microUSB power cable once charging is complete.
