Why Is the LED On My Smart Hub Blinking Green?
The LED on your Smart Hub will repeatedly flash green if the device does not detect any network activity. To resolve the issue, ensure an Ethernet cable is secured in the Ethernet port on the back of the unit and the other end is properly plugged into your home network.
Once a proper Ethernet connection is made, the LED on the Smart Hub will turn light blue and then disappear indicating a secure connection is made to your network.
0 out of 2 found this helpful
