How To Insert a MicroSD Card Into the AL-P402W
The device can support a microSD card of up to 128GB. Please make sure the microSD card is class 10 or above and properly formatted before inserting it into the camera. To locate the microSD card slot, move the camera portion upwards and open the cover. The microSD card slot is located next to the factory reset button.
Insert the microSD card into the slot and press in gently to secure it. Close the cover after the microSD card has been placed in the camera.
