The camera comes equipped with a power port connection, which requires a 12V, 2.0A power adapter and an Ethernet port which can be used as a secondary means of adding the camera to your WiFi network using an Ethernet cable. These connections are located on the dongle wire connection found on the back camera. Please note, Ethernet WIFI should be used as a secondary means of adding the camera to your network if the WiFi method is unavailable. For more information on how to to connect the camera to your network using an Ethernet cable click here.
Note: This is not a PoE camera and will require a 12V, 2.0A power adapter to function. For best performance, please make sure your camera is up to date on the latest firmware. To access the latest firmware, please visit amcrest.com/firmware.
