The camera can support a microSD card of up to 256GB. To insert a microSD card you will need a Phillips head screwdriver to open the "Reset" hatch on the camera as the microSD card slot is located in this area. Locate the Reset hatch on the camera and use a Phillips head screwdriver to open the hatch. Locate the microSD card slot and insert the microSD card into the slot, gold pins down, and press in to secure the microSD card into the slot. Place the Reset hatch on the camera and secure it back onto the camera.
