How To Playback Recordings Using Surveillance Pro.
To playback recorded material in the Amcrest Surveillance Pro software, navigate to the Home Page and in the Operation menu, click on Playback.
In the Device menu, click on the device you would like to view playback on. Ensure the checkbox next to the device name and group name are checked.
To begin, locate the search menu on the bottom left side of the playback interface.
Click on which device you would like to choose from in the Device menu. Once a device has been selected, choose which type of recording you would like to access from the Video Type dropdown menu. To view all recordings, select All Records from the dropdown list.
All recordings will be displayed in a 24-hour time frame format. Click on the calendar option in the Time field and select a start and end date in which to access a recording.
When a proper date has been chosen, click on the Search button to begin searching for the recordings. The recordings will then populate in the time bar and a record of each event will be displayed in the records field. To playback, a recording, select a recording from the records field and click the button.
For more information on how to download a recording, click here.
