How To View an Already Added Device In Surveillance Pro
To begin viewing an added device, navigate to the Home Page of the software and click on the LIVEVIEW icon located in the Basic section.
In the Organizations menu, on the far-right side of the live view screen, double-click the device you want to view to load the live feed into the viewer.
For more details on the features listed in this menu, refer to the table provided below:
Multi-Device Viewing In Surveillance Pro.
There are multiple viewing options available: 1, 4, 6, 8, 9, 16, 25, 36, 64, or Custom Split.
To create a custom viewing option click and the "Custom Layout" window will appear. Using the grid you can adjust the layout you prefer, whether it's for 2 cameras or more! Simply click "Ok" to finish creating the layout and apply it to your live view pane. Once again selecting one of the boxes and double clicking on a camera will display the video feed.
