An IP weatherproof rating is a two-digit code that indicates the level of protection that an electrical enclosure provides against dust and water ingress. The IP rating system is managed by the International Electrotechnical Commission (IEC).
The first digit of the IP rating indicates the level of protection against dust ingress, with 6 being the highest level of protection. This means that an IP65-rated enclosure is completely dust-tight.
The second digit of the IP rating indicates the level of protection against water ingress, with 8 being the highest level of protection. This means that an IP68-rated enclosure is protected against continuous immersion in water at a depth of up to 1 meter for 30 minutes.
Amcrest IP cameras are typically rated IP65, IP67, or IP68, which means they are completely dust-tight and can withstand temporary or prolonged submersion in water, respectively. This makes them ideal for outdoor use in all types of weather conditions.
Here is a table of the IP weatherproof ratings for Amcrest IP cameras:
| IP Rating | Dust Protection | Water Protection |
| IP65 | Complete | Protected from low pressure water jets from any direction, not completely waterproof. |
| IP66 | Complete | Protected against powerful water jets, not completely waterproof |
| IP67 | Complete | Temporary submersion in water (up to 1 meter for 30 minutes) |
| IP68 | Complete | Prolonged submersion in water (up to 10 meters for 72 hours). |
When choosing an Amcrest IP camera for outdoor use, it is important to consider the specific IP rating that you need. If you live in a climate with heavy rain or snow, or if the camera will be mounted in an area where it is likely to be submerged in water, you will need to choose a camera with an IP68 rating. Otherwise, an IP67-rated camera should be sufficient. These ratings can be found in the specs sheet for your specific model. For more information on IP ratings, click here.
What Are IK Weather Proof Ratings?
IK ratings, also known as impact protection ratings, are an international standard that indicates how resistant a product is to impact. The standard, IEC 62262, defines an IK rating scale from IK00 to IK10, with IK00 offering no protection and IK10 offering the highest level of protection.
IK ratings are determined by dropping a weighted hammer onto a product from a specific height and measuring the amount of damage caused. The higher the IK rating, the more resistant the product is to impact.
Here is a table of the IK rating scale and the corresponding impact energy levels:
| IK Rating | Impact Energy Level (Joules) |
| IK00 | None |
| IK01 | 0.14 |
| IK02 | 0.2 |
| IK03 | 0.35 |
| IK04 | 0.5 |
| IK05 | 0.7 |
| IK06 | 1 |
| IK07 | 2 |
| IK08 | 5 |
| IK09 | 10 |
| IK10 | 20 |
Products such as vandal domes and turret cameras with high IK ratings are well-suited for use in environments where they are at risk of being impacted, such as industrial settings, outdoor areas, and high-traffic areas.
