How To Download Recordings Using Amcrest Orion Surveillance Software
Recordings in the playback menu can be downloaded (exported) using the Amcrest Orion Surveillance software. To download the free software click here.
For more information on how to add a device into Amcrest Orion Surveillance software click here.
Downloading a Recording
Step 1: Open the Amcrest Orion surveillance software and select Download Center.
Step 2: Select the device in the Resources menu and click the calendar option in the Time menu. Select a date and time range of the recordings. Click OK.
Step 3: Click Search. Recordings can be accessed in a timeline or file format. If downloading from a timeline range, select a start and end time in the timeline, enter the software user password and click OK. Verify the start and end time of the recording and click OK. The recording will begin to download.
Step 4: Click the Downloaded tab to view and locate the storage path of the recording. Click the icon to locate the downloaded recording on your computer.
Note: If downloading multiple recordings, it is recommended to use the File menu. Select all recordings you want to download and select Download Selected File. To download a single file, click the Operation icon.
1 out of 1 found this helpful
