How to Customize Video Settings Using Amcrest Orion Surveillance Software
If you are having issues customizing the video settings for your device in the app then you can use Amcrest Orion Surveillance software to adjust these settings. This is free software provided by Amcrest and can be used as a one-stop surveillance source for all your Amcrest devices. To download the free software, click here.
For more information on how to customize the video settings, please refer to the information provided below.
Step 1: Open the Amcrest Orion software and select the settings mceclip0.png icon. Select Device.
Step 2: Select Device Config, select the device, and click Parameter Setting.
Step 3: Use the video settings options provided in the camera properties menu to customize the video settings. Click Apply.
Note: If you would like the video settings to apply to the device's web UI, click Link to Device Webpage.
