A microSD card is required to store events outside of the Amcrest Smart Home Cloud. The camera is
compatible with up to 256GB and requires a Class 10 or higher microSD card to function. It is highly
recommended to ensure the microSD card is properly formatted to FAT32 before proceeding.
To insert a microSD card, remove the lid on the top of the camera and locate the microSD card slot. Insert the microSD card into the microSD card slot with the gold pins facing towards the front of the camera.
Press down on the card until you hear a click and release. The microSD card will be secured in the slot. Secure the lid back onto the top of the camera after the microSD has been installed.
