Due to specific hardware limitations within the device, certain AI features may not be enabled simultaneously with other AI features. This is designed to allow the device to work more efficiently with any connected camera and reduce lag or other issues that may occur while in use.
Face Detection
Face detection is typically used in conjunction with features such as face recognition and may not be enabled when other features such as IVS (tripwire, intrusion, etc) are enabled. For more information on how to use face detection, click here.
Face Recognition
Face recognition is used in conjunction with face detection to locate and determine facial similarities detected by the system and may not be enabled if other features such as IVS (tripwire, intrusion, etc.) are enabled. For more information on how to use face recognition, click here.
IVS
IVS stands for intelligent video system analytics and is the basis for all the AI rules perimeter protection rules such as tripwire and intrusion. Both IVS rules and SMD features can be used simultaneously in the system, however, it cannot be enabled if features such as face detection, face recognition are enabled. For more information on how to use IVS features, click here.
SMD
Smart Motion Detection (SMD) uses an advanced algorithm to differentiate between human and motor vehicle shapes within a scene and send alarms only when a person or vehicle is detected. Please note, this option cannot be activated if face detection or face recognition is enabled in the system. For more information on how to use smart motion detection, click here.
