How To Use Face Recognition (AI DVR)
Face recognition is used in conjunction with face detection to locate and determine facial similarities detected by the system. Images are registered in a face library, by the user, and accessed via a face recognition smart search tool that is built into the DVR. A USB flash drive with applicable images (in jpeg format) should be inserted into a USB port on the DVR if you are importing images locally.
For more information on how to configure Face Detection, click here.
Step 1: Access the AI menu via the main menu.
Step 2: Click on the Face Recognition option in the Parameters menu and verify the correct channel is being used. Click on the Enable toggle switch to enable the feature. Click on Apply.
Step 3: Click on the Face Database option located in the AI menu and click on Add to begin registering images to a face library. A face library must be registered for this feature to function properly. Enter a name for your face library and click OK.
The library will now be saved to the database. Click on the Details section to begin adding images into the face library.
If you have a single image to add click Register if you have multiple images to add click on Batch register. Click on the (+) icon to add an image to be modeled into the system. Enter all credentials for the image and click OK.
Once the image(s) have been successfully modeled into the database left click on the interface to exit.
Step 4: Navigate back to the Face Recognition menu in the Parameters section and click on the Setting option in the Target Face Database field.
Select the face library you just created and click OK to insert the library of registered images into the interface.
Step 5: By default, the system will be set to Common Mode. Common mode allows the device to use the images registered in the face library to recognize faces, click the Enable checkbox to enable the face library.
Note: Enabling the Stranger Alarm toggle switch will alert the system once an unrecognized face is detected.
By default, common mode will detect a face image with 80% accuracy. To adjust the similarity percentage, click on the Modify icon, and enter an adjusted similarity percentage and click OK.
Note: To adjust Common Mode settings, click on the Parameters (gear) icon and select which additional options you would like to apply to this feature. Be sure to click OK to save the settings to your device.
Click Apply to save the settings to your system.
How To View Face Recognition Data
All face recognition data retained by the system can be accessed via the Face Recognition option located in the Smart Search menu. A search by attributes or a search by image can be performed. Searching by attributes will load all face recognition data found in the system whereas searching by an image will filter and display only the faces chosen by the user.
To search by attributes, enter a start and end time of the event in the interface and then click Smart Search. The interface will display all face recognition data. To view the event, click on the event you would like to view then click the play button in the interface.
To view specific face recognition data by image, click on the Search by Picture tab located in the Face Recognition interface.
If searchable images are already uploaded into a face library click on Face Library and select an image from the interface, then click Save to begin a search. If you would like to add images locally click Local Upload and follow the on-screen prompts to upload images. A USB flash drive with applicable images (in jpeg format) can be used to upload images to the DVR. Once an image has been loaded, enter the start and end times of the event and click Smart Search.
The system will display all face recognition data based on the image selected. All face recognition data can be backed up locally using a USB flash drive.
1 out of 1 found this helpful
