How To Set a Continuous Recording Schedule
A continuous recording schedule will allow the camera to recording 24/7 to a microSD card. This is only applicable to microSD card recording, cloud based recording will be human or motion detection only. For more information on how to set a continuous recording schedule, please refer to the information provided below.
Step 1: Open the app, locate the device and tap Settings.
Step 2: Tap the microSD card option.
Step 3: Tap Recording Mode.
Step 4: Tap Continuous.
By default, continuous recording mode will allow the camera to record 24/7 to a microSD card, however, a schedule can be applied that will allow the camera to recording continuously at specific days and times. To set a schedule, tap the Schedule option.
Enter the start and end time of the schedule. In the repeat menu, select which days of the week you would like to record. For instance, in this example we are telling the camera to record continuously but only between 6am and 6pm (18:00), Sunday, Tuesday, and Thursday. Tap Save to apply the continuous recording schedule to the device.
1 out of 1 found this helpful
