The device can support a microSD card of up to 128GB. Please make sure the microSD card is class 10 or above and properly formatted before inserting it into the camera. To locate the microSD card slot, look on the side of the camera, the microSD card slot will have a microSD card icon next to it.
Insert the microSD card into the slot and press in gently to secure it.
