How To Format a MicroSD Card Using An Amcrest Link Camera
 microSD card can be formatted using the Amcrest Link app. This will clear all data on the microSD card and format the microSD card to FAT32. Formatting the microSD card is performed using the microSD card menu under device settings. For more information on how to format the microSD card, please refer to the information provided below.
Step 1: Open the app, locate the device and tap Settings.
Step 2: Tap the microSD card option.
Step 3: Tap Format
