How To Install a MicroSD Card (IP5M-F1180EW-V2)
The camera can support a max of 128GB, Class 10 or above microSD cards. To Install a microSD card into your camera, please refer to the step by step guide below:
Note: For best performance, it is recommended to use a microSD card that is formatted to FAT32 before proceeding.
  1. Locate the microSD/factory reset button hatch on the side of the camera.
  2. Open the hatch to expose the microSD card/factory reset button.
Place a microSD card into the provided microSD card slot, gold pins down, and press to secure.
