How to Use Face Detection & Recognition (AMDV5M8, AMDV5M16)
Face detection is used to allow the device to detect and record face image events. Face recognition is used to locate and determine facial similarities detected by the system. Images for face recognition are registered in a face library, by the user, and accessed using a face recognition smart search tool that is built into the DVR. Please note, the DVR can support a max of 2 face detection & recognition channels. For more information on how to use these options please refer to the information provided below.
Step 1: Open a web browser and log into the web UI for your device. For more information on how to access the web UI, click here.
Step 2: Click on the AI option located in the main menu. Click on the Face Detection & Recognition option and click OK. Please note if you are switching AI Modes the DVR will reboot.
Step 3: In the Parameters section, click on Face Detection. Click on the Enable option to activate the setting. Please note, it is best to leave the settings as default, however, they can be adjusted by clicking on the Setting button. You can use your mouse to adjust the minimum (Min) and maximum (Max) size of the face detection area.
Step 4: When triggered, the face detection event will be retained in the face detection smart search menu, or snapshots of the event can be emailed to you. To have a snapshot of the event emailed to you, click the“Send Email” checkbox located in the More button. For more information on how to set up email alerts click here.
Step 5: Click OK to save the setting.
Viewing Face Detection Events
All face detection data retained by the system can be accessed using the Face Detection option located in the Smart Search menu. Enter a start and end date and time for the event you would like to view into the interface and click Search.
A display of all face detection image data will be displayed along with facial attributes. Click on the event you would like to view, and a clip of the event will be displayed in the built-in player. Click on the play icon to view the event. Please note, you may need to format your hard drive using the DVR for the face events to populate in the smart search menu.
How to Use Face Recognition
Face recognition is used to locate and determine facial similarities detected by the system. Images are registered in a face library, by the user, and similarities are accessed using the face recognition smart search tool to display the similarities.
Note: The images must be in jpeg format when registering to a library. This option requires the use of a plugin to function if using a web browser. It is recommended to use Internet Explorer when setting up this function.
There are 2 methods of face recognition, common mode, and stranger mode. Common mode allows the device to use the images registered in the face library as a reference to recognize faces. Stranger mode will alert the system once an unrecognized face is detected. For more information on how to set up common mode, please refer to the information provided below.
Step 2: Click on the AI option located in the main menu. Click on the Face Detection & Recognition option and click OK. Please note, if you are switching AI Modes the DVR will reboot.
Step 3: In the Parameters section, click on Face Recognition. Click on the Enable option to activate the setting.
Step 4: Click on the Database option located in the AI mode menu and click on Face Database Config. Click Add to begin registering images and create a face library. Enter a name for your face library and click OK. The library will now be saved to the database. Click on the Details section to begin adding images into the library.
Step 5: Click Register ID, enter the requested information, click the "+" option to add the image. Click OK. Click the "X" option to exit the details interface.
Step 6: Navigate back to the Face Recognition menu in the Parameters section and click on the "+"  option to import the face library. Click OK.
The similarity percentage will default to 80%. This will be the similarity threshold that the system will recognize the image. This percentage can be modified by clicking the gear wheel option under the parameters column. Please note, stranger alarm allows the system to alert once an unrecognized face is detected.
Step 7: Click OK to save the settings.
Viewing Face Recognition Data
All face recognition data retained by the system can be accessed using the Face Recognition option located in the Smart Search menu. A search by attributes or a search by picture can be performed. Searching by attributes will load all face recognition data found in the system whereas searching by a picture will filter and display only the faces chosen by the user.
To search by attributes, enter the start and end time of the event in the interface and then click Search. The interface will display all face recognition data. To view the event, click on the event you would like to view then click the play button in the interface.
To view specific face recognition data by image, click on the Search by Picture tab located in the Face Recognition interface.
If searchable images are already uploaded into a face library click on Face Library and select an image from the interface, then click OK to begin a search. If you would like to add images locally click Local Upload and follow the on-screen prompts to upload images. A USB flash drive with applicable images (in jpeg format) can be used to upload images to the DVR. Once an image has been loaded, enter the start and end time of the event, and click Search.
