How to Renew a Key in Blue Iris 5
Any expired keys in the Blue Iris 5 software will cause the software not to work with any connected cameras and may cause them to be inaccessible. Keys in the Blue Iris software provide up to one year of service from the initial start date of your license and will need to be renewed before they expire.
Note: Please ensure you are using the most up to date version of Blue Iris. To download the most up to date version of Blue Iris, click here.
For more information on how to renew your Blue Iris key, please refer to the steps provided below.
Step 1: Click on the settings menu (
) located in the top-left corner of the interface and select "Settings".
Step 2: In the bottom left corner of the Blue Iris Settings menu, click on the Upgrade/renew button to renew the key for your license.
Note: The new expiration date will be displayed in the menu and will be good for one year of the initial start date.
When you have purchased or renewed your account you will receive a new code in your email. Once the new key provided is entered into the Activation menu, press the "OK" button.
