How to Port Forward Your Amcrest NVR For Remote Access
Step 1: Open a web browser on your computer and  log into your device's web user interface (web UI). For more information on how to access the web UI, click here.
Step 2: In the Management section, select Network.
Step 3: In the Network menu, select the Connection tab and enter an HTTP port number into the HTTP Port field. This will be the port number which will need to be entered at the end of the URL to access your device remotely after it has been port forwarded in the router. For instance, in this example we will be using HTTP port 37779 however any open port between 1~65535 can be entered into the system. Please note, the TCP, UDP, and HTTP ports as they will need to be port forwarded in your router after this process is complete. Click Apply.
