The File menu allows the user to manage, share, and download clipped or manually recorded recordings or snapshots. The file menu can be accessed on the top banner of the home screen.
The manually taken snapshots and recordings will be in this menu. Tap to view a recording or snapshot. To share, export, or delete the event, tap the Select option and tap the event to select it. .
Use the share, export, or delete options.
Tap the share icon to send the recording via email, text, etc. from your phone. To save the file to your phone, tap the download icon. The event will instantly download to your phone.
