How To Setup Email Alerts Using A Helix IP Camera
Email Setup will be dependent on your specific email provider. In this example, we will be using Gmail. You will need to access your camera through the Web User Interface. For more information on how to access your camera on a computer through the web UI, click here
Once logged into the web UI, click the Settings option, select  "Network" and click SMTP (Email) Select your email provider from the list provided. This will automatically generate the SMTP server address, recommended SSL Encryption type, and port number for your email server.
SMTPServersmtp.gmail.com
SMTP Server Port: 465 will be for an SSL Encryption Type. If you would like to use a more secure encryption, use port number 587 and select a TLS encryption type.
Enter the email address you will be using in the Username field as well as the Google generated password in the Password field. To generate an app password, access your Gmail account, and click on Manage Your Google Account.
Make sure 2-step Verification is enabled, and in the search bar enter App Passwords. Enter a name for the app and click Create
Note: Notate the generated password provided by Google. This will be the password used to set up email notifications in your device.
Email Title: Enter your subject line here. (Ensure attachment is checked so that you get snapshots in your email.)
Sending Intervals: This Interval value determines the time in between emails you will receive for motion detection alerts. (Longer intervals will make it so that you do not get spammed emails constantly.)
Once done click "Apply". Click the Test option to test the connection. A test email notification will be sent if set up correctly.
If the email test is successful, you will then just need to enable email notifications (Send Email) option to be sent upon motion detection or other features that support this option.
