If using a microSD card, please make sure the microSD card is installed before the physical installation of your camera. To Install a microSD card into your camera, please refer to the step-by-step guide below:
Note: A microSD card with a max of 256GB can be used. Please make sure the microSD card is properly formatted to FAT32 and is classified as class 10 or above before installing.
Step 1: Locate the reset on the bottom of the camera (by the speaker) and use a Phillips head screwdriver to remove the hatch.
Step 2: Locate the microSD card slot and insert the microSD card into the slot. Press in to secure the card into the slot.
Step 3: Place the hatch back onto the camera and secure it using a Phillips head screwdriver.
