How to Turn Off Outside Doorbell Tones (AD410)
The outside tone volume of the doorbell can be adjusted or muted using the Amcrest Smart Home app. This is useful if you want to lower or mute the outside tone volume of your doorbell when the call button is pressed. For more information on how to adjust the outside tone volume of the doorbell please refer to the information provided below.
Step 1: Log into the Amcrest Smart Home app and tap on the Settings icon.
Step 2: Scroll down and tap on Doorbell Tone & Volume.
Step 3: Tap on Speaker Volume.
Step 4: Use the slider to adjust the volume of the doorbell tone up or down. Setting the slider to mute will mute the outside tone of the doorbell completely. The setting will automatically save once the volume has been adjusted.
1 out of 4 found this helpful
