How to Set a Human Detection Schedule Using Amcrest Smart Home
A human detection schedule allows you to set the device to begin recording human detection events at a designated time. This is useful if you would like the device to only start detecting events during specific times of the day. If you would like the device to record motion 24/7 you can leave the schedule as default. However, for more information on how to set a motion schedule, please refer to the information provided below.
Step 1: Log into the Amcrest Smart Home app and access your device.
Step 2: Tap on the Settings icon ( mceclip0.png ).
Step 3: Tap on Motion Detection.
Step 4: Tap on Human Detection Schedule.
Step 5: Tap on the day of the week you wish to modify. If you are setting a schedule for multiple days of the week this can be done later in the interface.
Step 6: Tap on "Add Schedule".
Step 7: Tap on “Start Time” and use the scroll option to select a time you want the event scheduled to start. Note: In this example, we will be setting the start time to 6am (0600).
Step 8: Tap on “End Time” and use the scroll option to select a time you want the event scheduled to stop. In this example, we will be setting the stop time to 5pm (1700). Tap on the back arrow ( Tap on “Repeat” to choose which days of the week you would like the motion schedule to apply. A green checkmark will be displayed next to the active days. Tap on the back arrow ( mceclip3.png ) to exit.
Step 9: Tap on “Repeat” to choose which days of the week you would like the motion schedule to apply.
A blue checkmark will be displayed next to the active days.
Note: Motion schedules cannot overlap.
Step 10: Tap on the “Save” button to save your motion schedule. To add additional motion schedules, you can tap on Add Schedule and repeat the setup process.
