How to Add Additional Users in the Web UI
A new user can be added to the camera which allows the admin user to customize and change user rights/authorities. This can be done by accessing the camera's web user interface (web UI) using a web browser. For more information on how to access the web UI, click here.
Step 1: Log in to the web UI and click on Setup
Step 2: Click on System and access the Manage Users tab, then click on Add User.
Step 3: Enter the username and password for the shared user. Use the Group dropdown menu to choose if the user will be an admin user or a shared user, and add a description if necessary.
Step 4: Select which permissions/authorities that will be applicable for the user and click Save. mceclip1.png
Note: This is optional, but a schedule to restrict a login can be set by clicking on the Restricted Login tab. Enter a start and end time for the schedule and which days it will be applicable. Click Save. image3.PNG
A new user will be added and the user can no log into the device using the set username and password.
