The AI features associated with your camera are only accessible and customizable using the built-in web user interface via a web browser.
The camera features the latest in JS technology which allows you to access your camera via a wide variety of web browsers including, Google Chrome, Firefox, Safari, and other mainstream web browsers via your PC or Mac computer, however, it is highly recommended to access the interface using Internet Explorer as some features (such as the AI Live menu) may not currently be available without the use of a plugin. For more information on how to access your camera from your computer please refer to the information below.
To access your camera from your computer you will need to first locate the camera’s IP address. To locate the camera’s IP address is it highly recommended to download our free Amcrest IP Config Tool software. The Amcrest
IP Config Tool can be downloaded at the following web page: amcerest.com/downloads
In the All Downloads menu, click on IP Config Software to begin the free download. Once the download has completed installing, locate the IP address associated with the device you would like to view in the browser.
Open a web browser and enter this IP address for your camera into the browser and press Enter.
In the web user interface, enter the login credentials for your device. If this is the first time accessing the device, the username and password will both be admin. Click on Login.
If this is the first time logging into your device, you will be prompted to modify the password for your device. To modify the password, enter the new password you would like to use in the New Password field and confirm. The password used should be between 8 and 32 characters long with a combination of letters and numbers.
Click OK when and allow the stream to load.
