A smart plan acts as a “master switch” for all AI and video metadata features associated with your camera. There are 2 types of smart plans, global and preset. A global smart plan is a preconfigured smart plan which only applies to features such as face detection and video metadata. A preset smart plan is a smart plan which is manually created by the user and can be applied to each AI rule (face detection, deep IVS, and video metadata.
Please note, it is highly recommended to manually set up a preset smart plan. For more information on setting up a preset smart plan, please refer to the information provided below.
Setting Up a Smart Plan
Step 1: Ensure the device is connected to your network and powered on, then, go to a computer and access the web user interface (web UI) using a web browser. For more information on how to access the web UI, click here.
Step 2: Click on Setup>>PTZ to access the Function tab and click on Add.
Note: To change the name of the preset, double click on the preset title and enter the title of the preset into the interface. Click the Save icon to save your presets.
Step 3: Click on Event>>Smart Plan, click on Add Plan, and select your preset from the dropdown menu.
Step 4: Select which AI rule the smart plan will apply and click Save to enable the smart plan.
Note: AI categories, such as face detection, deep IVS, and video metadata can only be applied to one smart plan at a time. If multiple AI categories are being used at the same time, a separate preset will need to be added and an additional smart plan will need to be enabled for the specified category.
