How to Format a Hard Drive on a 960H DVR
Formatting a hard drive will remove all data stored on the device. The hard drive can be formatted manually or via the device's interface. It is highly recommended to format the hard drive via the device interface first before having to manually format the drive. If you need to format your hard drive manually and would like more information on how to format the drive, click here.
For more information on how to format the hard drive via the device interface, please refer to the information provided below.
Step 1: Log into your DVR.
Step 2: Navigate to Devices >> HDD.
Step 3: Select your hard drive from the HDD menu and click Init to format the hard drive.
Note: Some models may have the "Init" option as format. Each option will format the hard drive.
1 out of 1 found this helpful
