How To Activate An Amcrest Smart Home Cloud Account
Amcrest Smart Home cloud is an optional premium cloud storage option provided exclusively for Amcrest Smart Home products. Amcrest Smart Home products are not compatible with traditional Amcrest Cloud accounts and will require activation specifically through the Amcrest Smart Home app. For more information on how to activate an Amcrest Smart Home Cloud account, please refer to the information provided below.
Step 1: Log into your Amcrest Smart Home app and select the device you wish to activate.
Step 2: On the live view screen tap on Cloud Recordings.
Step 3: Tap on Activate Cloud Storage.
Step 4: Select a Cloud Storage plan from the list of cloud plans and tap Buy
Note: Currently, we only offer motion detection storage plans. Continuous recording plans are currently not available for Amcrest Smart Home cloud plans.
Step 5: Enter your billing information into the billing form. All plans will require a credit card to process the request.
After you have purchased your Smart Home cloud account you will be able to store and view your recordings all from the Cloud Recordings menu. Additionally, you can change your plan, update your payment method, as well as cancel a subscription right from the app.
Note: Any plan changes made to your account will only take place at the end of your current billing cycle.
1 out of 3 found this helpful
