The Indicator light on your camera can be disabled or enabled using the Amcrest Smart Home app. For more information, please refer to the information provided below.
Step 1: Log in to the app and access your device.
Step 2: Tap on the Settings icon.
Step 3: Scroll down to the Indicator Light toggle switch and tap to disable it.
Note: If your device does not have an indicator light toggle switch, tap on Video Settings, then slide your finger on the carousel and locate the Indicator Light icon. Tap the Indicator Light icon to disable the indicator light. To enable the indicator light, tap the icon again.
