Power Issues When Directly Connecting to an NVR
Power Issues When Directly Connecting to an NVR.
If you are using a direct connection when connecting a POE+ camera to your NVR it is important to consider power consumption. If an NVR exceeds its power consumption limits, then any additional POE or POE+ cameras directly connected to the NVR cannot be powered by the NVR. For example, the NV41XXE-HS series includes 2 different models, 4 POE ports model and 8 POE ports models.
  • 4 POE ports model: max 25.5 W per POE+ port, and 50W in total.
  • 8 POE ports model: max 25.5 W per POE+ port, and 80W in total.
The power consumption of a single POE+ camera is around 20W each depending on the model. If the NVR’s power consumption have been exceeded, there are a few options that can be used; the additional cameras can be powered via an additional POE+ network switch or by using the included power supply.
IMPORTANT
if you are adding a camera to your NVR it is highly recommended to set your camera with a static IP address prior to adding it to the system. A static IP address can only be set in the camera’s web user interface on a computer. For more information on how to set a static IP for your camera visit: amcrest.com/staticIP
1 out of 1 found this helpful
