How To Access An Amcrest NVR Using a Web Browser
This device features the latest in JavaScript technology which allows you to access your device using a wide variety of web browsers including, Google Chrome, Firefox, Safari, and other mainstream web browsers using a PC or Mac computer. However, as a primary means of accessing the web user interface for your Amcrest device in a web browser, we highly recommend using Internet Explorer or Internet Explorer Mode in Edge as most modern browsers may provide certain limitations when accessing your device via a web browser.
To access the web UI using a web browser, please refer to the information provided below.
Locate the IP address for your device using the Amcrest IP Config Tool. The Amcrest IP Config Tool can be downloaded at the following web page: amcerest.com/downloads
In the All Downloads menu, click on IP Config Software to begin the free download. Once the download has completed installing, locate the IP address associated with the device you would like to view in the browser.
Enter this IP address into the browser and press enter to load the web user interface. Please note, if this is your first time accessing the interface, please follow the prompts in the device initialization screen to access your device.
Enter the login credentials for your device. If this is the first time accessing the device, the username and password will both be admin. Click on Login. Once logging in you will be taken to the main menu interface.
