How To Adjust Audio Settings
How To Adjust Audio Settings.
If your camera has audio capabilities you can adjust these settings directly. Audio settings can be adjusted by accessing your device on a laptop or PC via the device's web user interface (web UI). For more information on how to access the web UI for your device, click here.
Step 1: Log into the web UI for your device on a laptop or PC.
Step 2: In the web UI, navigate to Setup>>Camera>>Audio.
Note: If your camera does not have an Audio option, then the device is not compatible with any audio sources.
Step 3: This menu allows the user to modify audio settings for the camera. Below is an explanation for each of the fields listed in the Audio menu:
  • Enable: This checkbox allows the user to enable audio recording.
  • Encode Mode: This dropdown box allows the user to select what audio format the audio should be recording in.
  • Sampling Frequency: This dropdown box allows the user to select a sampling frequency for the audio. The options listed in this menu are 8k and 16k. 16k audio sampling allows for higher sound quality.
  • Audio in Device: This field allows the user to select what source to get audio from. The default will always be the camera's built-in mic. Alternatively, the line in mic can be selected.
  • Noise Filter: This dropdown box allows the user to enable or disable the audio noise filter function. This function helps to provide a cleaner audio quality when enabled.
  • Microphone Volume: This slider allows the user to adjust the microphone volume. The value ranges form 0 to 100. The default value is 50.
Step 4: To save the applied audio settings to your device, click on the Save option.
0 out of 1 found this helpful
