How To Adjust the Channel Title Overlay
The channel title overlay is the name that was given to the device. This is typically found in the lower left hand corner of the live view screen and can be adjusted in the web user interface (Web UI) on a laptop or computer. For more information on how to access the web UI for your device, click here.
Step 1: Log into the web UI for your device on a laptop or computer.
Step 2: In the web UI, navigate to Setup>>Camera>>Video>>Overlay>>Channel Title.
Step 3: Use the enable/disable radio buttons to enable or disable the channel title from the live view screen.
Note: If you would like to change the name of the channel title, input the name of the channel you would like to have for your device into the Input Channel Title field.
Step 4: To position the channel title overlay on the live view screen, click on hold your mouse pointer on the yellow, highlighted Channel Title box and use your mouse to move the channel title box to the area on the live view screen you would like to place it.
Step 5: Once you have finished adjusting your channel title settings, click on the Save option to save and apply the settings to your device.
0 out of 1 found this helpful
