How To View and Playback Trip Data
Trip data can be viewed using the Amcrest GPS web portal or the Amcrest GPS Pro app. For more information on how to view trip data, please refer to the information provided below.
Using the Web Portal (https://amcrestgps.net/)
Step 1: Visit https://amcrestgps.net and log into your GPS account.
Step 2: Click on Trips.
Step 3: Select the device from the Choose Device drop down menu.
A representation of the last reported trip will be displayed on the map interface.
Step 4: Click on "Choose a date" and select a date from the provided calendar. All days with applicable trip data will be represented with a green dot.
Note: Click on the More section to view the Last Trip, Today's Trip, Yesterday's Trip, or Custom Range Trips. Trip data can also be exported as a .pdf  or a custom pdf. Click on the Show Last 7 Days or Show Last 30 Days to display either the last 7 or 30 days of data. To run an animation of all data reported in the last 24 hours, click Run 24 Hr. To display all data retained in the last 24 hours, click Show 24 Hr. To delete trips, click on Delete Trips.
Step 5: Once a date has been selected, trip data for that day will be displayed. Click on Show Trip to display trip data for that specific route. Click on Run Trip to run an animation of the trip. Click on Summary to display details about the trip such as odometer readings, battery %, etc.
Using the Amcrest GPS Pro App
The Amcrest GPS Pro app is available for iOS and Android devices. Please visit the App Store or Google Play Store to download the app.
Step 1: Log into your GPS account.
Step 2: Tap on the main menu icon (  mceclip2.png ).
Step 3: Tap on Trips
Step 4: Select the device from the Choose Device drop down menu. Tap on Choose a date and select a date from the provided calendar. All days with applicable trip data will be represented with a blue dots.
Step 5: Trip data for the selected day will be displayed.
Information such as total miles driven, the date and time, duration, as well as automation options will be provided. For more information on options provided in this menu, please review the table provided below.
Run 24 Hr
Runs an automation of all trips recorded in the last 24 hours on the map interface.
Note: Tap the Stop button to exit the playback interface.
Show 24 Hr
Displays a route for all trip data recorded in the last 24 hours on the map interface.
Delete Trips
Deletes all trip data reported for that day.
Run Trip
Runs an automation of a single trip in the map interface.
Full Trip
Displays a route of a single trip in the map interface.
Summary
Displays the IMEI, average speed, minimum and maximum speeds, the average, minimum and maximum battery percentage of the device during a specific trip.
