How To Adjust Device Settings
The device settings can be adjusted using the Amcrest GPS web portal or via the Amcrest GPS Pro app. These options allow the user to enable or disable alert options such as, push notifications, email alerts, trip alerts, speed alerts, power on/off alerts, battery alerts, SOS Emergency alerts, disconnection alerts, tracker skins, etc.
Using the Web Portal (https://amcrestgps.net/)
Step 1: Visit https://amcrestgps.net and log into your GPS account.
Step 2: Select your device from the provided device list.
Step 3: Click on Settings.
Step 4: Use the provided toggle switches to enable/disable specific device settings.
Using the Amcrest GPS Pro App
The Amcrest GPS Pro app is available for iOS and Android devices. Please visit the App Store or Google Play Store to download the app.
Step 1: Log into your GPS account.
Step 2: Tap on the main menu icon (
Step 3: Tap on Device Settings.
Step 4: Use the provided radio buttons to enable or disable device settings.
For a description of the settings provided, please review the options below.
Note: The device can only reboot when the device is not reporting.
Device Name: The name of the device being used.
Alert Email: The email the current account email being used.
Mobile Carrier Primary: Select a primary mobile carrier.
Alert/SMS/Text Primary: The primary means of receiving SMS.
Mobile Carrier Secondary: Choose a secondary mobile carrier.
Alert Secondary SMS/Text: The secondary way of receiving SMS.
All Alerts: Enable to allow the device to receive all alerts.
All Push Notification Alerts: Enable to allow push notifications.
All Email Alerts: Enable to allow all email alerts to be sent.
All SMS/Text Alerts: Enable to allow all SMS alerts to be sent.
Trip Alerts: Enable to allow trip alerts to be sent.
Trip Push Notifications: Enable to allow trip push notifications.
Trip Email Alerts: Enable to allow trip emails alerts to be sent.
Trip SMS/Text Alerts: Enable to allow SMS trip alerts.
Trip Start/Stop Alert by: Enable G-sensor or Coordinate Change to start or stop a trip alert.
Speed Alerts: Enable/disable speed alerts.
Speed Push Notifications: Enable speed push notification alerts.
Speed Email Alerts: Enable/disable speed related email alerts.
Speed SMS/Text Alerts: Enable/disable speed related SMS alerts.
Speed Limit: Set MPH threshold for speed alerts.
Power On/Off Alerts: Enable/disable power on/off alerts.
Power On/Off Push Notifications: Enable/disable power related push notification alerts.
Power On/Off Email Alerts: Enable/disable power related email alerts to be sent.
Power On/Off SMS/Text Alerts: Enable/disable power related SMS alerts.
Battery Alerts: Enable/disable alerts to be sent if the battery is too low.
Battery Push Notification: Enable/disable a push notification to be sent if the battery is too low.
Battery Email Alerts: Enable/disable an email to be sent when the battery is too low.
Battery SMS/Text Alerts: Enable/disable SMS alerts to be sent if the battery if too low.
Low Battery % Alert ≤: Enable/disable alerts if battery percentage is less than or equal to a specified percentage.
SOS/Emergency Alerts: Enable/disable all SOS/Emergency alerts.
SOS/Emergency Push Notifications: Enable/disable SOS/Emergency push notifications.
SOS/Emergency Email Alerts: Enable/disable SOS/Emergency alerts to be emailed.
Charging Connected/Disconnected Alerts: Enable/disable alerts to be sent when the device is being charged or disconnected.
Charging Connected/Disconnected Push Notification: Enable/disable push notifications to be sent if the device is charging or is disconnected.
Charging Connected/Disconnected Email Alerts: Enable/disable email alerts to be sent if the device is being charged or is disconnected.
Charging Connected/Disconnected SMS/Text Alerts: Enable/disable SMS alerts to be sent if the device is charging or is disconnected.
Trip End Timer: Use this slider to set trip end times. This can range from 0 to 10 minutes; 10 minutes is set by default.
Vehicle Skins: Set the vehicle color in which the device is attached. The app will need to be reloaded for this function to be applied.
Note: Tap the Save button to save and apply settings.
