Amcrest Surveillance Pro - Adding A Device
Download the Amcrest Surveillance Pro Software. To download the software, please click here.
Once the software is successfully downloaded, the first step is adding the camera to the listed devices within the app.
The camera will now appear in the bottom table. In the "Operation" column select the pencil icon 1.png.
After it shows that it's 2.png you're finished!
After the camera has been added you can setup a storage device through PC-NVR within Amcrest Surveillance Pro to record video files directly to the HDD stored on your computer.
Also, you can view each of your cameras simultaneously through Amcrest Surveillance Pro through the Live View menu and other related software.
Note: Amcrest Surveillance Pro can only support up to of 50 devices in the device list.
0 out of 3 found this helpful
