Download the Amcrest Surveillance Pro Software. To download the software, please click here.
Once the software is successfully downloaded, the first step is adding the camera to the listed devices within the app.
Select "Devices" then find your camera listed in the "Online Devices" table.
The camera will now appear in the bottom table. In the "Operation" column select the pencil icon
Ensure that the username and password fields are correct. They will be set to default upon adding the device to the application's device list.
After it shows that it's
you're finished!
Also, you can view each of your cameras simultaneously through Amcrest Surveillance Pro through the Live View menu and other related software.
Note: Amcrest Surveillance Pro can only support up to of 50 devices in the device list.
