How To Setup Port Forwarding Using an Amcrest IP Camera
Note: Before port forwarding your device please make sure to setup HTTPS. For more information on how to set up HTTPS click here.
Step 1: Open a web browser on your computer and  log into your device's web user interface (web UI). For more information on how to access the web UI, click here.
Step 2: Click on Setup>>Network and access the Connection menu.
Step 3: In the Connection tab and enter an HTTP port number into the HTTP Port field. This will be the port number which will need to be entered at the end of the URL to access your device remotely after it has been port forwarded in the router. For instance, in this example we will be using HTTP port 37779. Please note, the TCP, UDP, and HTTP ports as they will need to be port forwarded in your router after this process is complete. Click Save.
Step 5: Once the ports have been properly forwarded in your router please verify the HTTP port has been properly forwarded. To verify this information, please visit canyouseeme.org enter the HTTP port into the Port to Check field and click Check Port.
1 out of 1 found this helpful
