Physical Installation Guide (POE Dome Camera)
To see a step by step instructional video on the installation of this camera, please click here.
IMPORTANT: Due to specific hardware limitations within your camera it is important to note that these devices will not be able to automatically pan/tilt or pivot in either the app or via the web UI on a computer. For this reason, it is imperative to make sure to mount the cameras properly and position them as efficiently as you can to the areas you wish to monitor. All positioning actions to the camera will have to be performed manually.
Prior to installation, please ensure that the installation environment can support at least three times the weight of the camera and the bracket. Also, make sure your camera is positioned to the correct position that you wish to monitor. For more information on how to position the lens for your camera please click here.
If you are using a mount or junction box or would like to see more information pertaining to these device, click here.
  • Power Drill
  • 3/16 Drill Bit
  • #2 Phillips Head Drill Bit with Extension, or a #2 Phillips Head Screwdriver
  • Hammer
  • Safety Glasses
  • 15/16th Paddle Bit (for in-wall installation)
3. Using a 3/16th drill bit and power drill, drill three holes on the X’s on the installation sticker. This is to allow insertion of the included expansion bolts (plastic wall anchors).
NOTE: Range of the lens: vertical (0°~+65°), horizontal (0°~+355°). When adjusting the camera into position, please ensure that the camera’s enclosure does not block the image or cause reflection of IR light.
3. Drill a hole on the placement sticker on the larger designated opening using a 15/16th paddle bit.
To assemble the RJ-45 cover:
  • Drop the small rubber washer into the plastic housing, then screw on the top cover.
  • Run the data cable through the weatherproof cover.
  • Install the RJ-45 connector to the end of the data cable to terminate the connection.
  • On the female data cable connector on the camera, place the large rubber O-ring around the end of the connector and pull it down. This is to ensure that water does not penetrate this connection when fully assembled.
  • Plug in the data cable and securely tighten the weatherproof RJ-45 cover.
  • Plug in the power cable and carefully insert all the cables into the hole in the ceiling or wall. Push the main cable through.
  • Align the three holes on the camera's base plate with the holes on the sticker on the mounting surface.
  • Insert the three standard installation screws and tighten them with your power drill to secure your camera to the mounting surface.
  • Reattach the dome cover back onto the mounted base of the camera and retighten the hex screws.
1 out of 1 found this helpful
